Insulation tester - what brand/type is ideal for electric motors
I have been looking on the net for a insulation
tester. I intend to use it mainly for testing motors.
I would like know what you would consider to be the
ideal tester for the task.
I have also been trying to locate information on
testing procedures. It has been very difficult to
find such information. I tried a search at this site
with zero results.
Do you know of any sites with motor insulation testing information? Do have any tips for testing?
I would greatly appreciate any information.
Respectfully,Ruben
with zero results.
Respectfully,Ruben
RE: Insulation tester - what brand/type is ideal for electric motors
Megger - Testing the insulation resistance and polarization index of windings (Avo, Fluke, Kyoritsu)
Surge Tester - Testing the turn-to-turn insulation, reversed coils, etc. (Baker, PJ Electronics)
AC HV test kit - Testing the high voltage withstandability of windings (many make them, google for ac hv tester)
DC HV test kit - Non-destructive (within reason) testing of the winding dielectric strength of winding (Google for dc hv tester)
Micro-ohm meter - Testing the winding DC resistance (Avo, Fluke)
* I would go green if only I were not yellow *
But times change and if I got back into service work in North America I would probably add equipment to measure total harmonic distortion, and possibly some type of multi channel recorder, maybe laptop based. Temperature measurement would also be good.
Bill
"Why not the best?"
Jimmy Carter
Here is a good PDF from http://avointl.com/, Fluke of coarse also has some excellent procedure information.
