Anchor Bolts,18J bar
Can somebody else explain to me what mean of anchor bolts, 18J bar? And what grade is this type of anchor bolts call??
Thanks.
Thanks.
RE: Anchor Bolts,18J bar
_____________________________________
I have been called "A storehouse of worthless information" many times.
With these 18J bolts, I then give the foundation person the base loads and anchor bolt diameter and let them pick the correct embedment length for the 18J's and design the drilled pier for the loads. I don't know much about how they do the foundation, but I hear phrases like "I take the loads given and apply a 1.5 overload then design the foundation". To me this is applying overloads on top of overloads.
In my line of work we would rather have the steel structure fail before the foundation fails so there is a chance that we can rebuild the structure on top of the old foundation.
