Vortex Shedding
Vortex Shedding
In ASCE 7-05, you cannot use the analytical procedure if your building has crosswind loading, vortex shedding, etc. Can anyone provide an explanation as to what vortex shedding is? Thank you
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Vortex Shedding
The tacoma narrows bridge is a good example of this.
Check here for a video...
http://www.youtube.com/watch?v=3mclp9QmCGs
"Why don't you knock it off with them negative waves? Why don't you dig how beautiful it is out here? Why don't you say something righteous and hopeful for a change?" Oddball, "Kelly's Heros" 1970
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
RE: Vortex Shedding
Structurally, the problem occurs when you incite harmonic effect via the vortex shedding. The presence of these does constitute a force to be dealt with, and can be very destructive if not designed for.
Mike McCann
McCann Engineering
RE: Vortex Shedding
Wiki has some good introductory material and pictures the last I looked.
RE: Vortex Shedding
Another place vortex shedding can occur is on cantilevered steel stacks. If it is a problem, strakes are usually added to change the frequency and formation of the vortecies. Strakes are either individual plates or a continuous plate applied in a helical pattern along the length of the stack.
RE: Vortex Shedding
