Welding high pressure hydraulic tubing
I'm having trouble finding out what code (ASME, AWS, SAE) applies to welding high pressure (6,000 psi) hydraulic tube assemblies. SAE J518 and ISO 6162 cover the flanges, but I haven't seen anything regarding weld requirements.
Can someone point me in the right direction?
RE: Welding high pressure hydraulic tubing
http://www.nfpa.com/
Bud Trinkel, Fluid Power Consultant
HYDRA-PNEU CONSULTING
http://www.redoxinc.com/s_weld.htm
