Epoxy Glu-In Wood Connection
Hello all,
I am working on a timber frame project where we need to use an epoxy and a steel rod for a tension connection between two members. Does anyone have experience with this and what type of epoxy did you use? Is there any trouble with using it on green wood and long term creep of the epoxy? Thanks.
RE: Epoxy Glu-In Wood Connection
