Visio, PDF, and Hyperlinks
Does anyone know if it is possible to create PDF's of Visio drawings which contain Hyperlinks, and have the Hyperlinks work for the PDF generated drawings when I post them on an Web server ? If so, can you point me in the right direction.
Thanks, Jack...
Thanks, Jack...
RE: Visio, PDF, and Hyperlinks
You will a full version of Adobe PDF Maker to either print to or to edit the document manually after creation.
There are other PDF programs that can do this also but AFAIK none of them are free either.
Remember...![[idea] idea](https://www.tipmaster.com/images/idea.gif)
"If you don't use your head,
your going to have to use your feet."
