Solid model constraints not transferring to nodes
This may be related to a recent question I posted regarding selecting geometric entities using their coordinates.
Using the APDL I first of all select a line using the LSEL command to apply a constraint.
Then I try to apply another constraint to a different line using LSEL again. However, this seems to overwrite the previously applied constraint on the other line. This can be seen by clicking on
List->Loads->DOF Constraints->On All Lines
I have made out a simplistic version of the problem below. The output window displays the following after the SOLVE command
"Constraint on undefined or unselected line 1 not transferred to nodes."
This doesn't happen if I manually select the lines. Does anyone know if there's something I'm missing out on here?
/CLEAR
/UNITS,SI
/prep7
!CREATE GEOMETRY
CSYS, 0
K, 1, 0, 0, 0
K, 2, 0, 0, 50
K, 3, 200, 0, 50
K, 4, 200, 0, 0
K, 5, 0, 50, 0
K, 6, 0, 50, 50
K, 7, 200, 50, 50
K, 8, 200, 50, 0
V, 1, 2, 3, 4, 5, 6, 7, 8
!CREATE MESH
ESIZE, 10
ET,1,SOLID92
MP, EX, 1, 3e9 MP, EZ, 1, 0.255e9
MP, GXY, 1, 0.38e9
MP, GYZ, 1, 0.38e9
MP, GXZ, 1, 0.38e9
MP, PRXY, 1, 0.022
MP, PRYZ, 1, 0.2
MP, PRXZ, 1, 0.45
MP, DENS, 1, 490
TYPE,1
VMESH, ALL
FINISH
!SET BOUNDARY CONDITIONS AND SOLVE
/SOLU
ANTYPE, STATIC
LSEL, S, LOC, X, 0, 0
LSEL, R, LOC, Y, 0, 0
LSEL, R, LOC, Z, 0, 50
DL, ALL, , ALL, 0
LSEL, S, LOC, X, 200, 200
DL, ALL, , UY, 0
ASEL, S, LOC, X, 0, 200
ASEL, R, LOC, Y, 0, 50
ASEL, R, LOC, Z, 0, 50
SFA, ALL, 1, PRES, 0.001
SOLVE ! Solve the problem
FINISH ! Finish the solution processor
(P.S. the reason the applied pressure if so low is because the problem will not solve otherwise. Rigid body motion occurs due to my problem applying the constraints)
/CLEAR
/UNITS,SI
/prep7
!CREATE GEOMETRY
CSYS, 0
K, 1, 0, 0, 0
K, 2, 0, 0, 50
K, 3, 200, 0, 50
K, 4, 200, 0, 0
K, 5, 0, 50, 0
K, 6, 0, 50, 50
K, 7, 200, 50, 50
K, 8, 200, 50, 0
!CREATE MESH
ESIZE, 10
ET,1,SOLID92
MP, GXY, 1, 0.38e9
MP, GYZ, 1, 0.38e9
MP, GXZ, 1, 0.38e9
MP, PRXY, 1, 0.022
MP, PRYZ, 1, 0.2
MP, PRXZ, 1, 0.45
MP, DENS, 1, 490
TYPE,1
VMESH, ALL
FINISH
/SOLU
ANTYPE, STATIC
DL, ALL, , ALL, 0
DL, ALL, , UY, 0
RE: Solid model constraints not transferring to nodes
DL, ALL, , ALL, 0
allsel,all,all
DL, ALL, , UY, 0
allsel,all,all
allsel,all,all
Garry
Thanks Garry. Much appreciated.
