Command Window
Command Window
Command Window
I am having trouble with microstation. I have turned on my "command window" at the base of my microstation main window. The command window has a key-in function and tells you what is going on. I want to change it back to the normal appearance with just the lock and snaps being shown as icons. Can anyone help me?
RE: Command Window
To get rid of the key-in window, you should be able to drag it out of the toolbar and then close it.
