Part information
Part information
Part information
SW 2006
How can I find all the assemblies where the same part is used in?
RE: Part information
Use SOlidworks explorer and browse to the file.  THere is a "where used" column that shows all the files that reference the document
Jon
jgbena@yahoo.com
Oh yeah.. if you are using a PDM tool such as workgroup or Enterprise, you can also get that info from there, again browse to the file..
in workgroup you need to Right-click on the file in the pdmworks workgroup vault and select "document info" and then select the tab "where used"
In enterprise you just need to browse to the file in the vault, highlight it, and read the "where used" information tab.
Jon
jgbena@yahoo.com
SW Explorer relies on Windows indexing.  Notoriously unreliable on network drives.
I have a tool that does a hard "house-to-house" search for where-used references.  Slower but much more reliable.  It will be published soon.
batHonesty may be the best policy, but insanity is a better defense.bat
http://www.EsoxRepublic.com-SolidWorks API VB programming help
