Foundation for a Jetty-- 2nd Request
I posted this question previously and received one comment. I am posting it a second time in case it has been overlooked or forgotten. I am looking for suggestions for a foundation for a jetty extending out perpendicularly from the shore 100 feet into a lake.
There is a small stream of highway drainage/runoff coming into the lake in a direction that will intersect the jetty at a 90 degree angle. The steam is very slow flowing unless there is a big rainfall. The stream is approximately 200 feet away from the jetty. I was told that during severe weather the stream shoots deposits out into the boat lane and the lane must be dredged. The jetty will help to contain the deposits so that it can be easier to control. The lake bottom is located at a depth below the water surface of approximately 2 feet along the shore to about 8 feet at the tip of the proposed jetty.
Originally, the jetty was proposed to be constructed of concrete blocks along the sides and front. The blocks are 2 x 3 x 4 feet and made from concrete. The jetty will extend about 2 feet above the surface of the water. The blocks will be placed along the sides of the jetty and compacted fill will be placed in the center. The surface of the jetty will be bituminous concrete (asphalt). The jetty will extend perpendicular from the shoreline of the lake.
The subsurface investigation made it difficult to design the jetty as originally planed. The investigation shows the lake bottom subsurface is comprised a four to twenty-two foot thick deposit of natural organic silt/peat overlying loose to medium dense deposits of natural glacial outwash. Natural glacial till was encountered in one test boring at a depth below the lakebed of 26 feet. The thick layer of loose organic silt along with the underwater construction limits the type of foundations available for the construction of the jetty.
I would appreciate any suggestions for the type of foundation and the construction methods. Cost is not a problem at the moment. One option that we are considering is pressure injected footings (PIF), with outside piles placed in a pier type arrangement to control lateral movement. However, even if we were to go with PIFs, there still remains the issue of how to construct the side walls of the jetty.
I would appreciate any suggestions you may have and thank you in advance for the advice.
MS
MS
RE: Foundation for a Jetty-- 2nd Request
See the text right below the thread title at the top. Copy and paste the "threadxxx-xxxxxx" exactly as it is from the old thread into the post when you do this and it will provide a link to the old thread.
The Previous thread is
thread256-205539: Foundation for a jetty
MS
MS
No one expected to hit the thick layer of silt, so it definitely throws a monkey wrench into the workings. If the jetty is to work as desired, it needs near vertical walls.
I'll will try a duplicate post on the coastal engineering forum. I could use all the advice and suggestions that I can get.
MS
We were considering sheet piling from the beginning. It is the thick layer of silt that has us concerned.
MS
