Max Discharge Eq.
Max Discharge Eq.
Max Discharge Eq.
Hi
What equation can i use to calculate the max discharge/flow through a 75mm pvc pipe?
RE: Max Discharge Eq.
Manning Equation
Darcy Weisbach Equation
Your question is too vague to answer more specifically.
bernoulli equation
If your pipe length is short, you might use determine the flow with an orifice equation.
