4130 steel not HTing to 38-42 Rockwell
I have more than one OP vendor having trouble getting 4130 steel, 2" thick plate to harden to 38-42Rc. When advising my customer they reported that several vendors are having trouble recently within the past few months. Has anybody heard of this problem? Is it new? Is there a bad foundry batch circulating?
RE: 4130 steel not HTing to 38-42 Rockwell
Is the spec for surface or core or both? The noted range should not be a problem at the surface but questionable in the core, at least at the center.
What is the quenchant? Typically 4130 is done in water or polymer. Need to have a qualified lab check microstructure.
What is the chemistry? Is it really 4130? Have the lab run a sample on a spectrograph.
Let us know...
The spec is for surface.
The material is 4130.
I haven't received certs yet to analyze chemistry.
My customer is fairly large (caterpillar large), so them saying that other vendors are reporting problems w/ 4130 as well, has me curious.
I would go ahead and have a piece of the stock analyzed for both chemistry and microstructure, don't wait for the cert, you can compare later.
The microstructure will confirm if the stock reached austenitizing temperature, and/or may indicate an issue with the heat treater's quenchant such as concentration, agitation, or contamination.
Are the other vendors using the same heat treater?
Low and/or spotty hardness on 4130 is not uncommon, particular with a 2" thick section.  4130 does not have very high hardenability, particularly for a 2" plate.
To achieve this hardness, you will have to have a well agitated water quench and make sure the water temperature is below 80 deg F.
rp
