Transformer Impedance Calculation from Test Data
I'm trying to determine the appropriate way to represent 3-winding Delta transformer to its equivalent Wye representation. The given data were: Primary : Secondary voltages, its MVA rating, MW loss, and %Z. I saw an old note in the past which indicates the calculated resistance as %R = MW loss * 100 / rated MVA. I didn't see any logic in this resistance calculation. If you have any links or advices to the above subject, please let me know. Thanks.
RE: Transformer Impedance Calculation from Test Data
%R = I^2 R * 100 / (I^2 Z)
I^2 * R = the resistive losses
I^2 * Z = MVA rating
Expressing the losses as a % of the MVA rating is what the formula does. It is common to all transformers - be they 2 winding, 3 winding or more.
A test report should give you the %Z between pairs of windings. With a 3 winding transformer, let's call the terminals H, L and T (high, low and tertiary).
Get 3 values from test report:
Z_H-L = impedance between H and L
Z_H-T = impedance between H and T
Z_L-T = impedance between L and T
Z_H = 1/2 (Z_H-L + Z_H-T - Z_L-T)
Z_L = 1/2 (Z_H-L + Z_L-T - Z_H-T)
Z_H = 1/2 (Z_H-T + Z_L-T - Z_H-L)
Looks better if you can use subscripts, but this should give you what you want. These impedances, Z_H, Z_L and Z_T are the wye equivalent values.
Truly appreciate for your help. Have a great day.
