Read/Write permissions
Good day all,
I have complete project that we had commissioned an outside supplier to do the design work for us on and when we received a copy of the CD with all of our data on it, every file was earmarked read only, with no write access. Is there a way to convert all the files within a directory at once to full accesses?
RE: Read/Write permissions
You can't change anything on the CD.
Scott Baugh, CSWP![[pc2] pc2](https://www.tipmaster.com/images/pc2.gif)
FAQ731-376: Eng-Tips.com Forum Policieswww.scottjbaugh.com
Maybe the CD or your drive is not re-writeable. You should copy everything to your hard disk, then if necessary select all the files and right click (RMB), select Properties and then uncheck "Read Only", then click OK.
Hope this helps.
Trevor Clarke. (R & D) Scientific Instruments.Somerset. UK
SW2007x64 SP3.0 Pentium P4 3.6Ghz, 4Gb Ram ATI FireGL V7100 Driver: 8.323.0.0
SW2007x32 SP4.0 Pentium P4 3.6Ghz, 2Gb Ram NVIDIA Quadro FX 500 Driver: 6.14.10.7756
See you a SW World next week!!!
Mike
Jon
jgbena@yahoo.com
