Counterbore Dimension Location
Am I doing something wrong here? When entering the information below I then point to a counterbore. If I select the outer circle (spotface) I do not get the counterbore values returned in the text. When I point to the inner circle (through hole) I get the correct result, but to me pointing to the inner circle is wrong in drafting terms.
6 - %DI%HS THRO
EQUI-SPACED ON 454.0 P.C.D.
S/FACE %DI%BS
Does anyone have any ideas?
M
v19
RE: Counterbore Dimension Location
this is corrected in V20. In V19/Sp10 it does not work the
way it should. So you have to live with that at the mo ...
dy
Cheers for that dy, it was annoying me :)
It doesn't seem to be corrected in V20 too. There are many other drafting convention problems still exists.
Example: I couldn't put angular dimension text to position where I wish.
Bhavesh
the problem mentioned by m4rc *is* solved in V20.
dy
now! You must tell in which environment you are. I usually
do not dimension a hole within the profile and thus I was
speaking of the draft environment.
The dimensioning will be OK in PMI and Draft but not within
the profile environment. Simply speaking: forgotten to fix
it in that environment too where it still snaps to the hole
I simply don't care of that, most important is: the drawing is
understandable and unambigous which IMHO it is either way
dy
sorry to attach part file, probebly it leads to confusion at your end. I am in draft environment.
I have persistant prblem in V20 draft. Counterbore dimensions need to attached at root hole, which doesn't seems standard way. (Arrow should be pointed at top of hole)
Bhavesh
