Sweet Service vs Sour Service
We are in the process of evaluating transferring a sweet service oil emulsion skid to a sour field. The system will operate at ~30 psig and the vessel has a 50 psig MAWP. The vessel is internally coated, so I believe the vessel to be suitable for this application, but what about the piping, isolation valves and psv which was all originally designed for sweet service?
Looking through Mr0175 it does not appear that sulfide cracking would be an issue at these low pressures. Am I correct in stating this or are there other things I should be worried about?
RE: Sweet Service vs Sour Service
Steve Jones
http://www.pdo.co.om/pdoweb/
