Creating simple hopper in SWX sheetmetal
Hi tere,
To my dismay I coudn't create a simple hopper having rectangular opeing at top and circular at bottom which also have edge flange at four sides on top rectangular opening.
I just wanted to create it and get flatten view,but SWX said there are limitations,you can't use base flange after loft command, even reverse is not possible.
Any try?
RE: Creating simple hopper in SWX sheetmetal
You'll find that there are things in real life that SolidWorks can't do, and things that Solidworks can do that can't be done in real life. It is the nature of the beast.
Jeff Mirisola, CSWP
Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
Every software package has its limitations.....I suggest you work within those "said" limitations or you can always do it in another MCAD package....lets say Inventor or Pro/E but I think you will find those packages also have limitations.
Have you had any formal SWx training?  How long have you used SWx or any other MCAD package (Pro/E, Inventor, & NX).
If you want help with this problem can you post a picture or the actual model.
Heckler   americanflag
Sr. Mechanical Engineer
SWx 2007 SP 4.0 & Pro/E 2001
      o
  _`\(,_
(_)/ (_)
This post contains no political overtones or undertones for that matter and in no way represents the poster's political agenda.
Here are a couple of links that have great knowledge base
http://mysite.verizon.net/mjlombard/
http://www.sheetmetalguy.com/
      o
  _`\(,_
(_)/ (_)
You could try modeling the part as a solid, then turn it into sheet metal with the insert bends command.
