Mechanical Joints Above Grade
Hi, I have been asked by a supplier to subsitute some flanged fittings for mechanical fittings in an above ground application due to timing/supply issues. The piping material is C900, so a mechanical restraint would have to be used in either case (like EBAA Iron or other). The piping would be supported by pipe hangers. Does anyone have experience with mechanical fittings above grade and know of any advantages/disadvantages.
RE: Mechanical Joints Above Grade
Perhaps these notes will help:
http://www.acipco.com/adip/specials/span.cfm
http:
Steve
With regard however to the basic piping question of a direct substitution of a mechanical joint vs a flanged joint (the latter with innate bolt “restraint”), there could be concerns as well depending on the specific design of restraint to be used to keep the plastic pipe end from pulling or deflecting out of the socket.
Also, (as I think at least intimated in bimr and SteveWag's good responses) a standardized mechanical joint for a fitting or valve has a socket depth or "stab length", wherein the pipe typically penetrates some distance up into the socket (I think up to about 2-1/2" deep on smaller pipe sizes, and deeper on larger). Unless the fitting is a mechanical joint sleeve, the pipe can therefore not be as easily lifted or withdrawn laterally from a line, even after complete unbolting of the joint, as can a flanged or grooved coupling pipe , say in piping/valving etc. replacement, re-routing or maintenance operations etc. e.g. as by very slight spreading apart of the flanges etc.) In other words the pipe end up in a mechanical joint can hang up on the penetrated socket end. This behavior may or may not be a future problem in the specific piping configuration/application, with sometimes other flexibility.
I will note also there are other sorts of devices available in the general piping field including e.g. "flanged adaptors", some of which offer a basic field-adaptability (cut to suit), a mechanical sort of sealing mechanism not unlike mechanical joint on one end with a flange connection on the other, and some even offer separate restraint features as well as more easy lateral pipe withdrawal features. Again however you might want to contact the manufacturers involved to make sure they are happy with use of these devices/restraints etc. with the specific above grade plastic piping application.
