Nylon Spacers
4
Nylon Spacers
Nylon Spacers
Hello everybody,
I am looking for a nylon spacer for a 2-56 machine screw with a length of 9/32" or 7mm. I have been looking all over but all I can find is a version on McMaster which is over a dollar per spacer, I could get them machined locally for probably less. So if anybody has an idea, maybe in China, please let me know.
Thank you very much in advance
Domenic
RE: Nylon Spacers
thank you, but I have tried them already they didn't have the length I need
RE: Nylon Spacers
How about Micro Plastics - They are really fast at sending out samples.
https://secure.microplastics.com/catalogpictorial.aspx
Heckler   americanflag
Sr. Mechanical Engineer
SWx 2007 SP 4.0 & Pro/E 2001
      o
  _`\(,_
(_)/ (_)
This post contains no political overtones or undertones for that matter and in no way represents the poster's political agenda.
RE: Nylon Spacers
By samples from Mcmaster, and see if there is a manufacturer named on the package.
RE: Nylon Spacers
The Tick has a good point.  I've bought stuff from McMaster Carr and it comes in the original mfg packaging.....then I know the supplier.  I've only been able to get the supplier from a MMC rep once and it was only because they didn't carry the size I needed.
      o
  _`\(,_
(_)/ (_)
RE: Nylon Spacers
thx a lot guys, but once again I have also looked through microplastics and 9/32 seems to be a real oddball. I will however try the sample method.
Cheers
RE: Nylon Spacers
Not necessarily right for your situation but…
At my place we’ll often pick parts out of McMaster, order enough for prototypes etc.
When it gets into production our purchasing people frequently get an equivalent item from a local hardware supplier (http://www.specialtytoolandbolt.com/).  [Don’t get me started on how equivalent is determined…]
So do your purchasing people have a preferred supplier you could go to, or have you already asked them/doesn’t apply to your situation?
KENAT, probably the least qualified checker you'll ever meet...
RE: Nylon Spacers
a qoute to local suppliers is out at the moment so we are waiting to hear back from them.
thanks for the quick reply
RE: Nylon Spacers
I would give Bokers a call assuming any quanity.
They have sent me a sample packet that included the one off size I needed.
http://www.bokers.com/
