Sketch display in drawing view
How I can display a model sketch in its drawing view?
RE: Sketch display in drawing view
Assuming you are in draft. Right click on the view, select properties, select Display tab, select 3 button over on the top - Part list options, and select List sketches, you will see your sketchs in the parts list, select the sketch or sketches you want to view and check the "show" button, apply and update your view and you should see the sketch.
Best of luck,
Jamie
Thanks Jamie,
This works perfect.
I am trying to retrive sketch having image to represent it on drawing view. It shows only imager border when I follow your instr.
Bhavesh
