Drawing Title Block
Drawing Title Block
When I add additional sheets to a drawing, I have to keep adding the information to the title block. What do I have to do so the information in the title block on sheet 1 is copied to any additional drawing sheets that I add????????.
Danoo
Danoo
RE: Drawing Title Block
You can also make a 2nd sheet in your drawing format that has a condensed title block with less info. Our sheet 2 only has company name/logo, drawing title, revision, sheet # & P/N.
