edrawings
edrawings
edrawings
Is it possible to open an edrawings file in Solid works so it can be converter to stl or another format?
Cheers...
RE: edrawings
Depending on how the eDrawing file was saved, you may be able to save to STL format from eDrawings.  Otherwise, I don't see a way to open eDrawings files with SolidWorks.
Jeff Mowry
www.industrialdesignhaus.com
What did you dream?  It's all right--we told you what to dream.
    --Pink Floyd, Welcome to the Machine
RE: edrawings
We have a problem with eDrawings 2008.
When you save a marked up eDrawing as a jpeg the markup isn't saved with it and doesn't appear on the jpeg.
Why is this?  2007 Did it.
RE: edrawings
Theo is correct,
you cannot open an derawing in solidworks, you can however save an stl out of an edrawing IF the publisher of the edrawing set the option to allow someone to save out as STL.
Jon
jgbena@yahoo.com
