HCl passivated
HCl passivated
I have heard about so called passivated HCl that is a blend of Formaldehyde and Hydrochloric acid.
I is used for cleaning of pipes, .....
I'd like to know how much less corrosive the HCl becomes, to steel, when formaldehyde is added.
Does it make a great difference to add the formaldehyde?
RE: HCl passivated
RE: HCl passivated
Plymouth Tube
RE: HCl passivated
I knew that nitric is used for passivation.
What I try to determine is how effective formaldehyde is, a corrosion inhibitor that is added to what some European suppliers call "acide passivé", that is probabbly the same thing as inhibited HCl.
Would anyone have experience with such acids?
