Section View in Drawing - Turn Off Hatching
When doing a Section View in a Drawing file, is there a way to turn off the hatch marks? Or maybe change the spacing between the lines in the hatch (i.e. I could make the spacing something huge like 1000mm, so there would be almost no hatch lines on any of my parts).
Ken
RE: Section View in Drawing - Turn Off Hatching
This is defined in the Drafting Standards file.  Search the forum for more info.
Like catiajim writes, the default settings are controlled by the xml file. But you can right click on the hatch it self and change it
Ken,
Double click on the hatch, and from pattern tab, change the option from Hatching to Color and put white color.
-Hora
