drying room
drying room
we are currently operating a drying room, and are using two 8kw ac's to remove moisture from the room. Room temp is around 60 degrees celsius. We need a more effective way of removing moisture? Should we use chilled water through evaporators? or R22 refrigeration plant? 20 kw required
RE: drying room
RE: drying room
need more information, you are drying something, what is it and how dry does it need to be? This will determine how "cold" the dehumidifier needs to be. Once this is determined the recomendation for either refrigerant or chilled water can be made.
regards
Mark Hutton
RE: drying room
