Bolting for Duplex Stainless Steel Flange
Generally, I applied B8 (SS304) bolting for duplex stainless steel flange bolting. I think that this has no problem.
However,
I think that B8 bolting is not suitable if the bolting is in the environment that Chloride Stress Corrosion Cracking could occur.
Someone recommended to use B7 (1.0Cr-0.5Mo) bolting.
However,
In my opinion,
Application for B7 bolting could cause galvanic corrosion between low alloy steel and duplex stainless steel.
Is it right?
what is the solution for this problem if it was right?
At this point of time, it is difficult to apply the isolated kit for bolting.
RE: Bolting for Duplex Stainless Steel Flange
SS 304 can crack (CSCC) in an atmosphere with high chloride (eg marine atmosphere)
The suggestion of Cr-Mo bolts is correct provided they are hot dip galvanized.
If if you look in Norsok specification for piping, L 001, they specify STUD BOLT C/W NUTS  A193 B7/A194 2H
with Surface protection, "All low alloyed steel bolts, nuts and washers shall be hot dipped galvanized according to ASTM A 153."
http://www.standard.no/imaker.exe?id=1355
hope this help
S.
http://www.corrosionist.com
If you are really concerned you should use duplex or Ni alloy bolts.  Yes they are expensive and a pain, but they will do the job right.
Plymouth Tube
strider6,
I don't understand how hot-dipped galvanized low alloy steel bolts are expected to provide long service life when in contact with high chromium content steels in a marine environment.  Are they supposed to be replaced at regular intervals?
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Careful if considering nickel 718 to ensure it is in accordance with API 6A718 and that they are not over-torqued, and that the hardness is 100% checked to be below 35 HRc, otherwise they could crack if there is any CP near...
Z100 super duplex would work also and is commonly used for bolting.
Riadsala
Metallurgist in the Offshore O&G industry
