recommend velocity nigtrogen in pipeline
How is common recommend velocity for nitrogen gas - in the pipeline?
for natural gas should be around 30m/sec
katarina
RE: recommend velocity nigtrogen in pipeline
For long pipeline work, you should be generally shooting for a velocity that gives a pressure drop of around 0.5 psi to 1 psi/mile.  30 m/s is very fast.  I would try to limit velocities to 10 m/s unless in very short segments of a compressor station, or other facility where you might consider velocities as high as 20 m/s.
http://virtualpipeline.spaces.msn.com
"We can't solve problems by using the same kind of thinking we used when we created them." -Albert Einstein
Whoops.  NOT per MILE!  per 100 FEET!
Thanks very much for help and tip :)
k.
