Motors, Delta vs Star Connection.
Something I have wondered for years. The difference between delta wound motors and star wound motors when the going gets rough. I know that both configurations work equally well on good systems. But, when the system is less than perfect; (unequal voltages, unequal phase angles, unequal voltages and unequal phase angles) does one configuration perform better than the other?
Thanks in advance.
Thanks in advance.
Bill
"Why not the best?"
Jimmy Carter
RE: Motors, Delta vs Star Connection.
But IIRC, there was mention by someone of Y wound motors being more fault tolerant, although I don't recall being persuaded by the argument they put forth.
