Synchronize & Compare Two Analog Signals
I am looking for a circuit design that will allow me to synchronize two incoming analog signals (one reference and one unknown) which would allow me to compare them to see if they are similar or different.
I am not to familiar with appropriate terms and phrases like, "phase lock loop"....etc. This is sort of hindering my search results.
The specifications for the circuit are not really important right now seeing as I am looking for the function first. However, as a reference, I will use +/-5V AC signals with no greater than 100kHz frequencies.
Thank you
Thank you
RE: Synchronize & Compare Two Analog Signals
TTFN
We want to compare these signals to pre-recorded signals that pose as a baseline/reference.
It's going to be a much different problem if you're comparing two sine waves than if you're comparing two arbitrary waveforms.
In general, the waveforms will be DC with some transients (~450us).
What exactly are you trying to measure... feeding us info piecemeal isn't going to get you a useful answer and will more than likely just annoy everyone until we give up.
Dan - Owner
http://www.Hi-TecDesigns.com
good luck
TTFN
http://en.wikipedia.org/wiki/Lock-in_amplifier
Note Basic principals.
Keith Cress
Amateur EME or professional something-or-other?
(Excuse the thread hijack...)
Keith Cress
How similar?
How different?
TTFN
