Should units be included following both numbers in a range?
3
Is there an authority that suggests units should be included following both numbers in a range?
For instance, 125 N to 500 N versus 125 to 500 N ?
I have always used the latter method but recently heard the former method is correct.
David
RE: Should units be included following both numbers in a range?
The bottom of page one in this PDF, http://online.physics.uiuc.edu/courses/phys499/Fall07/TechnicalWritingRules-Aug07.pdf, suggests that only one copy of the unit should be included but the units are not the topic of discussion.
A space is shown between the number and unit unless the unit is preceeded by the degrees symbol, °.  I don't believe I was taught this but have always wrote units in this way because it looks proper to me.
David
3
The "former" is recommended.  Please refer to Section 7.7 of NIST Special Publication 811 Guide for the Use of the International System of Units (SI), available here:
http://physics.nist.gov/Pubs/pdf.html
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Thanks Cory, that guide appears to be exactly what I was looking for.
David
That is an excellent link.  Thanks.
- Steve
