Time-dependent rotation component
Hi all
Is it possible to apply the time-dependent angular velocity of the rotation component (the function between angular velocity and time. For example acceleration or slowdown of the impeller)?
Artem
RE: Time-dependent rotation component
If you are asking about CosmosMotion - then yes it is possible to acribe a time dependent motion velocity to components.  You can do this by specifying mottion on the joint and dicate which type of motion and the functions that would describe it.
Sorry, I've forgotten to specify the Add-In.
I have in my mind Cosmos FloWorks. Is it possible to do in this Add-In?
Artem
