warning msg.
warning msg.
How to avoid this warning?
The elements in element set WarnElemFailElemInContact are part of a deformable surface that is referenced by a *CONTACT PAIR option in addition to having material properties that allow the element to fail. For elements that can fail, contact should be defined using the *CONTACT option.
RE: warning msg.
Martin Stokes CEng MIMechE
RE: warning msg.
