Residential garage door header
Designing a steel beam over a 16' wide garage door opening supporting trusses 3 feet above. Do you consider the steel beam laterally supported or assume unsupported the entire length? It appears obvious, just looking for an opinion.
RE: Residential garage door header
Sustainable, Solar, Environmental, and Structural Engineering: Appropriate technologies for a planet in stress.
