Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...What a great service! This is the best site I've ever seen!!! It totally restores my faith in humanity when people take time out to help other people..."
Geography
doehl1 (Electrical)
12 Jan 08 15:48
We have a short-run diesel fuel pipeline that has been installed in quite a dusty, dirty environment.  We need to flush the line to prevent downstream contamination of components. Debris in the line ranges from very fine to 50-75 micron.
My question is:  What fluid velocity/Re number do we need to achieve to maximize the transport flushing effect?
System details:
1) Piping will be flushed with diesel fuel.
2) Pipe is sch 40 carbon steel black pipe with line sizes of 3" and 4".
3) I have a pump available which can deliver 350 gpm at 100 psi.  For flushing, and without overrunning the pump, I expect we'll be able to achieve 450 gpm or slightly higher.
4) We want to filter down to at least 20 micron on the discharge end of the pipe.
5) Pipeline segments to be cleaned have distances that range from only a few meters to over 650 feet.
Please advise, and thanks in advance for your assistance.
doehl1
BigInch (Petroleum)
12 Jan 08 17:38
You can try running at around 10 ft/sec to see what you can clean.  Be careful with valve openings, closings and pump starts and stops at that velocity.
To get what that doesn't clean, if necessary you might try running a series of cleaning pigs.  Cleaning pigs will be much more effective than running at a higher velocity.  Additionally, if there are some gum residues and plaque coatings you want to get at, running batching pigs with a solvent or specialized detergent between them might loosen them up.
http://virtualpipeline.spaces.msn.com
"We can't solve problems by using the same kind of thinking we used when we created them." -Albert Einstein
rngrrix (Petroleum)
13 Jan 08 21:43
The line pigging is a good suggestion or as an alternative and since this sounds like new construction you may want to consider pulse air blows followed by recirculation with diesel through a bag filter.
Close Box
Join Eng-Tips® Today!
Join Us             Close
