Hard Annodizing 5052 H32 Aluminum
I am working on a problem with friction wear between two parts.  One of them is hard annodized 5052 H32 Aluminum.  My question is what is the hardness of this material after the annodizing process.  I have looked several places, but have so far been unsucessful finding a spec on this.  Any references you can suggest for annodized materials would be helpful.
RE: Hard Annodizing 5052 H32 Aluminum
as hapens so many times in the engineering world... it depends; there is a wide range because "hard annodising" is a typical or broad term. so you need to learn more about it so you can then nail down your supplier. start at this page then go to the index - warning - only when you have a lot of time.http://www.alu-info.dk/Html/alulib/modul/A00313.htm
