Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...On your site I feel quite confident that the contacts and feedback will make my life a little less hectic..."
Geography
1BrickShort (Aerospace)
11 Jan 08 17:42
I have a reed switch that has been working properly for multiple cycles, then out of the blue it is showing a short circuit. The reed switch itself has been soldered to a circuit board and embeded in epoxy, so I do not have the luxury of being able to physically touch the switch or board.
Has anyone seen an effect on a reed switch that would cause it to suddenly short for no good reason, then remain shorted indefinetly even though there was no magentic field present?
Is it possible for a voltage spike to cause this? What else could cause this effect?
I am confused by this.
The idea of embeding the switch assembly in this expoxy has been proven through experience on the product line, so I am fairly convinced that the effect is not coming from the efects of the epoxy...
Does anyone have an idea as to what this could be?
1BrickShort
IRstuff (Aerospace)
11 Jan 08 17:54
As with any switch, overcurrent can potentially cause the contacts to weld together
TTFN
14 Jan 08 15:56
Well, the welded reeds was the correct answer. I found a potentiometer this morning that was shorting in the circuit and causing the failure. Through testing I could repeat the effects consistently...the conclusion is that we shouldn't nessisarily buy from the cheapest bidder!!!
Thanks for the input
1BrickShort
Close Box
Join Eng-Tips® Today!
Join Us             Close
