Section VIII Div 1 - UG-84 (i)
Under "Vessel (Production) Impact Tests Plates" (UG-84 (i) of Section VIII Div 1), there is the following statement about the materials used to make the test plate:
"The vessel impact test plate shall be from one of the heats of steel used for the vessel..."
What's a valid interpretation of this?  That if the vessel is made from SA-105 and SA-516 Gr 70, the production test plate could be made from just the same heat of SA-105?
RE: Section VIII Div 1 - UG-84 (i)
yes....same heat
Or JUST the SA516-70.
Also, keep in mind, one test plate is req'd for each process used, on cat A & B joints.
Thank you both for your input.
What about a cat D joint?
Don't worry about production testing the Cat D's.  See UG 84 (i)(3)
