ROTATING .JPGs
ROTATING .JPGs
ROTATING .JPGs
Hi all
Can an inserted .jpg be rotated in an assembly drawing other than increments of 90 degrees?
RE: ROTATING .JPGs
If the image is the face of a part, you should be able to rotate it (using mates) by whatever angle you need. Or by dragging if the other DOFs are suitably constrained.
cheers
RE: ROTATING .JPGs
CBL
Inserting the jpg files into a drawing does not allow any mating or manipulation other than that offered thru the paint toolbar. Here I can only flip the image, or rotate in increments of 90.
RE: ROTATING .JPGs
You missed my point. Place the image onto a separate part first, and then insert that part into the assy.
cheers
RE: ROTATING .JPGs
CBL
I do not see where mating options are eligible, but importing the picture via Tool, sketch tools, sketch picture... does give positioning options. Thanks
