Underline spacing when creating pdf's
When I create a pdf from a drawing file, the underline spacing increases and almost overlaps the text beneath it. I've attached two images. One is taken from Solidworks and the other is taken from the pdf. Anyone else having this issue?
Sean
Carmanah Design and Manufacturing
Vancouver, BC, Canada
www.carmanahdesign.com
RE: Underline spacing when creating pdf's
When creating the PDF, make sure you have the Embed fonts option selected.
Have you tried different PDF creators?
I haven't tried any other pdf creators. I'm using the default one that comes with Solidworks. I've been using it for every version of Solidworks that's been available and this only started happening once we upgraded to 2008.
Sean
See attached image. PDF on top, SLDDRW below.
http:
It sets up as a printer, and I haven't noticed any differences between the actual print, and the PDFs that it creates.
SW must be using a different PS to PDF convertor.
