What's stronger, F1554 GR 36 Rod OR A325 Bolt
I'm connecting a web plate on each side of a column and I'm using a rod with threaded ends through the column. The fabricator wants to use F1554 GR 36 rod and I can't find any shear or tensile values, other than that it has the same properties as A36 steel. I have values for A325 bolts but how does this compare to the F1554 GR 36? Gr 55 and 105 are also avialable. I'm using 3/4" diameter fasteners. Thanks.
RE: What's stronger, F1554 GR 36 Rod OR A325 Bolt
A325 has Fu around 105 ksi.
http://www
Though the topic is not steel to steel connection, at least it indicates some distiction between high strength bolts and anchor rods.
h
