formula for pressure to volume
I'm trying to find a formula that will determine what the volume of air is at varying pressures.
example: 1 cubic ft. of air at 100 psi
What would the volume be at 75 psi
at 50 psi etc.
Is there a formula that would make it easier to determine this??
at 50 psi etc.
RE: formula for pressure to volume
P1/P2 = V2/V1 where P1 and P2 are the ABSOLUTE pressures and V1 and V2 are the volumes. To convert from psig to absolute pressure, add the atmospheric pressure (14.7 psiA at sea level) to the gauge pressure. For example, 100 psig would become 114.7 psiA at sea level.
Doubling the absolute pressure will half the volume and so on.
PSIG Ration of Compression
10 1.68
20 2.36
30 3.04
40 3.72
50 4.40
60 5.08
70 5.76
80 6.44
90 7.12
100 7.8
110 8.48
120 9.16
130 9.84
140 10.52
150 11.2
200 14.6
