Import .dwg 3D to Sw
Hello, sorry for my poor English.
I need to know if you can import a file. Dwg 3D made in autocad solidworks to work?
RE: Import .dwg 3D to Sw
I'm assuming you mean a solid model? If so, you'll probably need to save it as a *.step, *.x_t, or *.iges file, import into SolidWorks and run FeatureWorks on it.
Jeff Mirisola, CSWP
Certified DriveWorks AE
http://designsmarter.typepad.com/jeffs_blog
Dell M90, Core2 Duo
4GB RAM
Nvidia 3500M
1. Edit in DWG editor
2. Create a new Solidworks Drawing
3. Import to a new Part.
4. Import MDT data from file (imports as parts, assy's, & drawings)
Normally the MDT option is grayed out unless there is 3d data in the file. When you get a drawing from Mechanical desktop, you will see that option is available. Select it and it will import all of the ACIS surfaces from the file.
Jon
jgbena@yahoo.com
All great ideas, here is another one.
In AutoCAD export the solid data (ACIS .sat file). Open the the ACIS .sat file in SolidWorks.
cheers,
In fact I received a 3D. Dxf (not solid) done in autocad not in MTD, but to import it into SW with the wizard, this makes me the first model curves imported. To make it a solid I use imported from 3D curves as a sketch and then make extrución or cutting them to make the solid model.
This is so, is the correct way to work or another?
Thanks for help
