odd marks on journals / bearings
Hello Guys,
I've been sent through some photographs that show odd longitudinal marking on the journals and bearings
I suspect that they're caused by the journal roundness, but would appreciate any views (apologies for the quality of the photographs)
Tony.
Clickable photographs back to 800x600 image
Tony.
RE: odd marks on journals / bearings
Thanks for replying. I wondered the same thing, although it uses a gas turbine as prime mover, there is no barring equipment attached to generator
Tony
It is hard to tell, I assume that the top photo the bearing surface? What does the thrust look like?
My first thought was that it might be electrical discharge... but that would be fairly rare (although not impossible) on a gas turbine generator train. Have you had any electrical problems with the generator? If this is a generator bearing, are the bearing(s) properly insulated?
Might also be acid etching. Take a lube oil sample and get the TAN and water content checked.
How deep are the marks? can you feel them with your finger nail? Have a look with a magnifying glass. Do they look like pits with melted bottoms?
"Why don't you knock it off with them negative waves? Why don't you dig how beautiful it is out here? Why don't you say something righteous and hopeful for a change?" Oddball, "Kelly's Heros" 1970
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Field service vibration analysis for several New England grinding houses often was in search of similar visual patterns. Often grinding wheel trim balancing improved the situation.
http://en.wikipedia.org/wiki/Longitudinal
I see longitudinal (axial) marks on the bearing.
I see circumferential marks on both the bearing and the journal.
I suspect the original poster is talking about the circumferential marks since he said both bearing and journal.
I am under the impression that the comments about machining of the bearing are referring to the axial marks.
I guess it looks like 80 per rev on the journal, but more like it would be a 160 on the journal
high vibration while the bearing is simply not turning or at rest.
Do journal bearings also have rolls in them? I always thought that no. But these marks look like they were typical, although weak, EDM marks in a roller bearing.
Gunnar Englund
www.gke.org
Just an oil filled clearance..
Gunnar Englund
www.gke.org
If generator, does the generator have jacking oil?
Are the bearings insulated? Is either of them (hopefully not both) grounded? Or, should I ask are they both grounded or neither insulated?
IF it doesn't have jacking oil, is it a unit subject to lots of starts?
rmw
Thanks for the all the replies
The shell and journal are the DE of a 5MW 4pole sych generator coupled to a Gearbox and then a GT - again I apologize for the poor quality photographs and especially having the shell photo upside down
We were called to check the generator bearing insulation and shell condition after 'somebody' looked into the g/box and saw bluing of the teeth which was attributed to low generator bearing IR ?, unfortunately that is all the detail I have on that discussion
but to answer some of the questions;
Hi Pete, Apologies for the confusion, I am discussing the marks that along the length (the long axis of the rotor) of the journal and shell, not the ones that are circumferential.
I haven't been to site, but the report back is that these indications cannot be felt; but please me tell more about acid etching in a bearing, this is new to me.
The unit dose not have jacking oil
but is not subject to a high number of starts, industrial generator which provides a base load to the plant.
and the bearing IR is good.
again thanks for the all the comments
Cheers
Tony.
posibly the transfe of some teeth contact force on the journal. wouldn't the DE bearing be grounded?
regards
John
