SJI joist girder as moment frame
Steel Joist Institute fabricators can design their products for end moments for use in moment frames.  Can a SJI joist girder be used for seismic loads in an IBC06 seismic design category D building?  If so what would you use for the basic seismic force resisting system and response modification coefficient?
RE: SJI joist girder as moment frame
In a SDC "D" - No way you can use a joist system as your primary lateral members.
That is what I figured.  The SJI manual only talks about wind moments.  I have also asked SJI about this and apparently they have a new release of their Technical Digest #11 that is due out this week, which deals with lateral moments.  They have told me that it is greatly expanded and includes seismic moments.  I will repost once I see what they have.
