Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Thanks for creating this site - I expect to be visiting it often as I continue to try to grow my bag of tricks!..."
Geography
sennafan (Structural)
10 Jan 08 19:03
I am discussing repair of the surface of exterior slabs on grade with a property owner.  The slabs were exposed to 2 or 3 unknown chemicals that have discolored and mildly etched the surface.  The owner is adamant that no coatings or cementitious overlays be used for fear of poor long term performance.  When I suggested sand blasting and/or grinding, he questioned whether the durability would be decreased.
I suspect we will only lose 1/16" to 1/8" of the surface to get rid of the effected concrete.  The area is prone to freeze thaw and extremes of hot and cold weather.  My thinking is that, if anything, blasting or grinding should remove the upper layer of cement paste and leave a stronger, possibly less porous surface unless we uncover air voids from poor consolidation or voids any exposed aggregate.  Any thoughts or references to support or argue against my thoughts on this?
GeoPaveTraffic (Geotechnical)
11 Jan 08 8:10
State highway departments often remove the top 1/16 to 1/2 inch of interstate pavements, it's called diamond grinding and they do it to improve ride quality.  I can't imagin them doing that if the durability would be decreased.
As for using sand blasting, that could cause micro-cracks in the near surface concrete which could decrease durability.  I would suggest a non-impact grinder.
civilperson (Structural)
11 Jan 08 14:54
Prior to surface grinding, raise the Ph by application of a base solution.
dik (Structural)
11 Jan 08 22:11
civilperson... why raise the pH?
Dik
12 Jan 08 12:47
civilperson - I am also curious about the benefit of raising the ph.
GeoPaveTraffic - my one hesitation about grinding is the fear that the resulting surface might become too slippery for foot traffic in bad weather.
Thanks to both of you for the responses,
sennafan
14 Jan 08 9:48
There are many types of grinders.  Some leave the surface (as you fear) very smooth, others leave it very rough.
14 Jan 08 11:57
Original post listed two or three unknown chemicals which discolored and etched the surface.  Without knowing for sure, I would assume a acidic solution to produce this condition.  A program of grinding will not change the acid situation, (and the continued deteriation), thus my recommendation to raise the Ph prior to repair.
Close Box
Join Eng-Tips® Today!
Join Us             Close
