Steel Studs Joist blocking supporting loading bearing wall
Can anyone tell me the code provisions for required steel stud joist blocking under a load bearing steel stud wall. Does the code address this issue? Are there any recomendations? My basic concern is if it has to be solid blocking under the wall.
RE: Steel Studs Joist blocking supporting loading bearing wall
