composite structure
composite structure
Hi all forum, I am modelling a composite structure (I beam + concrete slab), i used shell elements for both materials. I applied 4 nos points load (100kN each) on the beam, but there was no respond in my result, i not sure what went wrong, can anyone help? attched my *.inp file.
RE: composite structure
Rob Stupplebeen
how to include gravity and stabilization as you suggested? sorry, as i am new on abaqus and this is my first model.
the slab is sitting on the beam and I applied the point loads on the beam's nodes instead of slab's nodes.
For stabilization in the CAE User's Manual 15.13.3. Check your energies at the end of the analysis to make sure that the energy associated with stabilization is small relative to the rest of the energy.
Hope this helps.
Robert Stupplebeen
