Decimal places in the distance command
Is there any way of changing the ammount of decimal places in the distance command display, I have a user here at JCB who has no decimal places after the main measurement so he's getting for example 300mm instead of 300.1824  I have attached an image so you can see what I'm on about
Many thanks
Simon.
RE: Decimal places in the distance command
Good question, but if I need more accuracy, I use the information icon.  More decimal pts than I'll ever use.
Believe it if you need it or leave it if you dare. - Robert Hunter
Check out:
Preferences -> User Interface... -> General Tab
Dialog Box Decimal Places
Change that to the number you want.
Good luck!
Chris Cooper
Senior CAD Specialist
Cleveland Golf / Never Compromise
www.clevelandgolf.com
www.nevercompromise.com
Got it sorted, thanks to those who helped.
