Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...This is a very good site. Please keep it running. Thanks and wishing a great health and success for the site and its owners..."
Geography
angelmar (Mechanical)
10 Jan 08 6:44
I´m facing a maintenance issue related tubing cracks(subsea control valves hydraulic system tubing) and would appreciate your help for identify the main cause and solve it appling engineering best practices.
Briefly: Leaking was observed in OD 1/2" hydraulic tubing, after analyses micro-crunches was found, apparently initiate by surface exthernal corrosion.
Aditional information:
Material order inform ASTM A312TP316L
Material analysis found: %C:0,017, %Mn:1,59, %Si:0,49, %Cr:16,75,%Mo:2,18, %S:0,001, %P:0,016,%Ni:9,63.
Down hole 7500 PSI
I´m planning to replace all tubing (down hole and the others) as soon is possible for attribute reliability , cause it I need to identify the correct one. (please inform standards if possible).
Thanks in advance
Helpful Member!  strider6 (Materials)
10 Jan 08 15:44
consider the use of duplex materials.
Article (769KB) by Joseph W. McEnerney (P.E. Gibson Tube Inc., USA); "Experience manufacturing alloy 19D (UNS S32001) seam welded lean duplex stainless steel tubing for subsea umbilical applications"
http://www.stainless-steel-world.net/pdf/McEnerney.pdf
Application of duplex stainless steel in the offshore industry
http://www.stainless-steel-world.net/pdf/D97_208.zip
S
http://www.corrosionist.com
Helpful Member!  SJones (Petroleum)
11 Jan 08 4:19
Define the exposure environment, including any corrosion control measures, as thoroughly as possible before selecting a material then follow the Institute Of Petroleum Guidelines For Design, Installation & Maintenance Of Small Bore Tubing Systems where appropriate.
Steve Jones
http://www.pdo.co.om/pdoweb/
Close Box
Join Eng-Tips® Today!
Join Us             Close
