Shaft sinking advice
I'm designing a large storm holiding tank. The volume is 6000m3 (1585000 gallons). Its all under ground. The ground conditions are:
0-9m (0-29.5') soft SILT
9-14m (29.5'-46') soft CLAY
14-16m (46'-52.5') GRAVEL
on LIMESTONE BEDROCK
The ground is saturated up to surface level
The tank is to be approx 25m (82') diameter and 16m (52.5') deep.
My initial design was to use a secant pile wall down to bedrock, then excavate and build a RC tank in the void.
The contractor has suggested shaft sinking instead - I had considered this, but at Tender stage there was no local company with a 25m shaft capacity.
I like the idea, but my question is how do I stop the soft saturated soil 'running' from the outside to the inside of the shaft as it is being sunk. I know that we will have to pump out water, but what about a 'running silt'?
Apologies for the long question, any advice will be appreciated.
RE: Shaft sinking advice
This is not just a dig and see what happens. It does require a lot of planning and engineering before and during construction. However, if the contractor has experience with the technique, it can be very effective.
The contractor's method is as you've described, and they do have 30 years experience with this. I've discussed grouting and freezing to stabilise the ground, but due to the cost the contractor are opting not to go down that route, and accept the risk. They seem confident that they can excavate effectively.
When you say "Running ground is reduced by excvating in the wet" - do you mean that we shouldn't try to reduce the water table?
